need advice in macros
Hello macro experts!
I need use UF_DRAW_extracted_edge to change current view style in drawing
could  someone give the simple example...
I dont know when should  use session when ufsesssion and what is difference...
thanks
RE: need advice in macros
if the function you want to use has UF at the start it needs a UFsession.
I think the syntax for that command would be
Ufsession.Draw.extracted_edge
That's just off the top of my head and needs to be checked.
Mark Benson
Aerodynamic Model Designer
i didnt get what extracting edges for drafting mean..
  Just giving a tip not a solution for your task
  Session object is .NET reference where as UFsession object is UFUNC Open C wrappers reference
  you need to instantiate these two to get hold on the current NX session and operate on the function calls
i wanted to have toggle  between none and associative in drawing view style ...
my code is
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Utilities
Imports NXOpen.Drawings
Module Module1
    Sub Main()
        Dim  i, j As Integer
        Dim theSession As Session = Session.GetSession()
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim drtag As Tag()
        Dim v_tag As Tag()
        Dim numd As Integer
        Dim numv As Integer
        Dim PartName As String
        ufs.Draw.AskDrawings(numd, drtag)
        For i = 0 To numd - 1
            ufs.Draw.AskViews(drtag(i), numv, v_tag)
            Dim v_par As UFDraw.ViewPrfs
            For j = 0 To numv - 1
                v_par.extracted_edges = 1
                ufs.Draw.SetViewDisplay(v_tag(j), v_par)
            Next
        Next
    End Sub
End Module
it failed with error
NXOpen.NXException: Input is not a valid parameter.
at NXOpen.UF.UFDraw.SetViewDisplay(Tag view_tag, ViewPrfs& view_parms)
at NX.Module1.Main() in nx://root/Script:line 29
   You have declared the structure for view preferences, but it needs to be initialized for all the values it has. you are supplying only the extracted edges input.
Try using this way....
    ufs.Draw.AskViewDisplay(v_tag(j), v_par)
Next
Now the whole of the structure instance is poppulated with the default values..will get modified in the subsequent statement and then the update is driven.
thanks very much,HariharanB!
please could You help in another thing
i need to turn on autoupdate in Sheetmetal flatpattern...
can not manage...
code:
Sub set_smd_pref
    'sheet metal preferences setup
       dim smd as UFSmd
       dim fp_options() As UFSmd.FpPrefs
      smd.AskFpPrefs(fp_options)
       fp_options.auto_update = true
    End Sub
  Find the corrected code below with appropriate comments
  Sub set_smd_pref()
        Try
            ''' / Need to get the session object /
            Dim UFS As UFSession = UFS.GetUFSession
            ''' / Do not access wrapper class objects directly
            ''' They cannot be instantiated, but only the shared
            ''' elements can be accessed /
            'Dim smd As UFSmd
            Dim fp_options(-1) As UFSmd.FpPrefs
            UFS.Smd.AskFpPrefs(fp_options)
            With fp_options(0)
                MessageBox.Show("Existing auto update preferences value :" + .auto_update.ToString)
                ''' / Check the default value before overriding /
                If Not (.auto_update) Then
                    fp_options(0).auto_update = True
                    MessageBox.Show("Value succesfully changed to TRUE")
                End If
            End With
        Catch ex As Exception
            MessageBox.Show(ex.Message)
        End Try
    End Sub
thanks very much - it works...
experience is forever thing! :)
