lamination test
lamination test
lamination test
Hi, is there anything in ASME about lamination test (UT) on plates over 20 mm in thickness?
RE: lamination test
I would suggest looking into MIL-STD-810, Labratory testing procedures.
Its not a detailed instruction, but gives a direction to go and you can fine tune it for your application.
Everett#2390
RE: lamination test
Please see ASTM A-578.
RE: lamination test
maryam,
It depends on what section of the ASME Code you are working with.
Section VIII Div 1 - no requirement
Section VIII Div 2 - AM-203 - UT if over 4"
Section III - NB-2531 - UT if over 2"
I am sure there are different requirements in other sections.
JR97
