cast glass
cast glass
does somebody work with large cast glass objects? What are the physical properties of cast glass, and, more important, what are the strength properties under high compression stress?
RE: cast glass
-when loaded uniformly glass will usually hold up under 40KPSI or more, about 1000psi under tension - See Yoder, books on optical component mounting SPIE press
Schott has data on failure of glass with rate of application of load - not the same as static loading
Commercial gass glass probably somewhat less
-See McLellan & Shand Glass Engineering Handbook McGraw Hill
