Deck Beam Splice
Deck Beam Splice
40'x6'deck supported by a ledger on one side and a (2)2x10 beam on the other. The beam would be bolted to 6"x6" posts at 10 ft O.C.
Any recommendations on how to connect two beams at the same post or how to splice the beamas would be appreciated.
RE: Deck Beam Splice
Or any of numerous Simpson face mounted hangers.
See Simpson Catalog C-2007.
ht
Never, but never question engineer's judgement
The posts are continous that also support the canopy above but they can be cut and modified. When the beam is continous at the post location or at teh last post, there is no problem bolting them together. The problem would be at the beam splice. If spliced at the post locations the bolt edge distance would only be 1 3/8".
I am leaning towards face mounted hangers per "lkjh345".
_________________________________
|________
_______________|______________
