Strap Footing vs. Combined Footing
A long time ago when I was designing larger buildings, I had to design a lot of combined footings. One time however, I had to design a strap footing. I can't remember why I had to use a strap instead of a combined footing. Can anyone explain when it is appropriate to use a strap footing over a combined footing? I also forgot the simple design of the strap footing. Can anyone refresh my memory?
RE: Strap Footing vs. Combined Footing
A strap footing is a beam that is supported by two spread footings, cantilevering over one of them. The column near the property line or existing building sits at the tip of the cantilever.
DaveAtkins
I designed many combined footings where the exterior column was next to the property line but I guess I was always able to get the pressures to work so I never had to ask what happens when they don't. The only time I designed a strap footing was on a project where I was working with a 70 year old engineer. (We started the same day. I was 23. He was 70. He liked to travel around the world.) Anyway, it was a column for a long span truss over an atrium that was part of an addition to a hosptial. He must have known by experience or by running a quick number that a combined footing wouldn't work. I can't remember if he ever explained why or I forgot to ask. It was a VERY fast track project.
Isn't that what a strap footing is? A grade beam cantilevering over one footing, with the back span going to another footing (preferably with a column on top of it)?
DaveAtkins
