CT kneepoint
CT kneepoint
CT kneepoint
If a CT has name plate Kneepoint of 750Volts. Should the measured (actual) value be Higher or lower than this figure and what is the tolerance ie 5%,10% etc
Thanks in advane
RE: CT kneepoint
Measured should be higher.
Normally it's stated as Vkp >= 750V (for example).
There is no tolerance per se...higher is better.
RE: CT kneepoint
the rating on the side of the CT is the Minimum value that you should obtain. It also should correspond with the formula to calculate Vkp= S/(Ns*ALF)
" THINK BIG "
