Axial expansion of Stainless Steel Tubing
I would like to know how much axial expansion (inches or mm) that I can expect from 12" dia. schedule 40, 304 and 316 Stainless steel tubing when continuously exposed to 210F. Could I get a formula?
RE: Axial expansion of Stainless Steel Tubing
length * coeff of linear expansion of steel * temp change =
change in length.
temp change is the difference between normal room temperature and the temperature your tubes working at.
In degrees centigrade the expansion for a metre length will be:-
1m * 12 * 10^-6 * (99-20)= 9.48 * 10^-4 or 0.948mm
regards
desertfox
There are very useful tables on the expansion of SS,CS and other materials in the Appendices to ASME B31.1 and B31.3
Excellent reference....
Tell us of your problem and results......
Math review is free on this forum
-MJC
