Compression Ring Design
I have a roof structure shaped like an octoganol pyramid (8 sides coming to a single point in the center). Total clear span is to be about 200'. I am thinking of using steel joists/trusses come to the center, and sit on a compression ring.
Anyone got any tips on the design/analysis or know of any good references to look at?
RE: Compression Ring Design
"Design and Construction of the Tension Braced Dome Roof Marine Midland Arena- Buffalo, New York."
Mike McCann
McCann Engineering
