VFD Overvoltage Problem
Recently we had an incident on a bus feeding multiple PWM style VFDs, motor loads and small transformers. The bus is high resistance grounded, limited to 2 A. Over a span of about 3 hrs, 3 drives tripped and a transformer shorted to ground on the primary. Several of the drives would not restart. They would immediately trip on overvoltage. Finally, another drive tripped. The drives that would not start due to overvoltage then started. We found the last drive that tripped was feeding a motor that was faulted to ground.
Is ther any way a groundfault on the output of a VFD would show up as an overvoltage trip on other drives on the same bus?
RE: VFD Overvoltage Problem
So, to sum it up, this switching of the phases to ground is ugly and who knows what other problems could arise from it unless you a detailed investigation of what exactly is happening at the other drives.
