Need help finding info on this M.V. Fuse
This fuse is in an indoor 12kV switchgear, it feeds an indoor transformer. I want to model it in Etap to conduct an arc flash study. I don't really care much about the manufacture, just want info on it so I can cross reference it with a common fuse type from one of the other popular manufactures.
I have no idea what it is.
http://i48.photobucket.com/albums/f223/majesus/DSC00681.jpg
Anyone see the logo or company before?
RE: Need help finding info on this M.V. Fuse
I found out through google translator
überstromfest overcurrent firmly
schlagstift impact pin
I think I am out of luck trying to find info on this fuse.
Looks like a standard European DIN medium voltage fuse. Plenty manufacturers, here is ABB's catalogue page:
http://www.abb.co.uk/product/us/9AAC754112.aspx?country=GB
Sometimes I wake up Grumpy.
Other times I just let her sleep!
Thanks, on the SLD is has the following:
EPE 200A
I'm not sure what the EPE stands for?
There is another similar substation that has a 150E fuse. I'm assuming that is an  “E” Designation: Fuses rated 100E or below will melt in 300 seconds at a current value between 2.0 and 2.4 times the E number. Fuses rated above 100E will melt in 600 seconds at a current value between 2.2 and 2.64 times the E number. If the current is higher than 2.4 or 2.64 times the E number, the user must consult the time-current curves for that particular fuse.
I did not realize that was the definition of an E fuse.
This happened to me twice: In both cases, I found out that they were Driescher fuses.
