color library
color library
color library
Using Wildfire 2.0,how can I make a library of all of the colors I want and then have that library be availible for every part I design?
RE: color library
WF 2.0 and 3.0 now use the APPEARANCE.DMT file for colors. Both versions will read previous COLOR.MAP files and save those as the APPEARANCE.DMT. You can save the .DMT files on your local drive or a network directory but you must set the PRO_COLORMAP_PATH in your config.pro and point to the directory/folder where it is located. For example my config setting looks like this: PRO_COLORMAP_PATH c:\colormaps\
Eholmes
RE: color library
I can not get Pro/E to follow the pro_colormap_path but it will read a file in the startup working directory.
