Sprinklers in MCC Room
In the case of MCC Rooms, is there an exception to a typical bujilding department rule requiring fire sprinklers if an area exceeds, say, 5000 square feet?
If the MCC room has firewalls, is it exempt from the sprinkler requirement?
RE: Sprinklers in MCC Room
I don't get the logic, but that's what I've seen happen.
Good Luck.
Keith Cress
