Zoom about screen center toggle
This isn't affecting me....mine's fine. But three people in my group are have trouble with View -> Modify -> Zoom about screen center.
It seems to be locked in that mode regardless of whether you toggle it on or off.
Like I said, mine's just fine. But it's weird that it's happening to three people here....I suggested that the problem was between the chair and the keyboard, but it does seem to be stuck.
RE: Zoom about screen center toggle
Mouse, settings, video cards, ???
You could try copying you settings (using the Copy Settings Wizard) to their machines as a quick first kick-of-the-can fix.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Open SW, close, then reboot their pc's.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
I guess I should have mentioned it. Sorry...
Works fine on both my monitors.
Chris
AutoCAD 06
What do I know... I'm management now.......
Run Catia on monitor 1 and SW on monitor 2 and the zoom to mouse doesn't work.
Run SW on monitor 1 and Catia on monitor 2 and everything
is fine.
Good tip thx.
