MAWV for API 650 Tank
I have a job to put nitrogen blank into an api650 tanks.
Before that, I need verfy the MAWV for this tanks.
The tank have column-supported cone roof and covered by V7.1.
Has nothing on Truss-supported Cone Roof Tanks ? How do we proceed with designing the roof for Vacuum in such cases ?
RE: MAWV for API 650 Tank
Joe Tank
Request a detailed third-party design review by an experienced "storage tank" engineer. (I am assuming that this vacuum rating is not incorporated into any design drawings that you have in your records)
Do not be surprised and disappointed if your existing tank cannot sustain MAWV as little as - 3IWC.
The design vacuum is an issue that cannot be successfully applied to existing tanks ..... it must be incorporated into the design before that tank is built.
This is my opinion only
-MJC
Our process guy want apply 1" wC on it. Per the latest API650 appendix V, Vacuum lower than 1" WC do not need any additional calculation.
My question is that my old tank can exempt calculation due to this item?
Thanks for your advice MJCronin.
Have your process guy on top of the tank when the 1" vacuum is applied
Its only fair......
-MJC
Even back in the 1960's API's position was that tanks built to the minimum requirements of the standard could withstand 1" water vacuum without anything additional. If you can find API on the nameplate, a nameplate drawing, or find the certification letter certifying that the tank was built to API 650, you're home free. I would have to look at my superceded issues of API 650 to confirm, but I don't believe hat API addressed truss assembly supports back at the time this tank was built. That may be your hang-up.
Best of Luck
I found that +/- 1.5 WC design pressure was shown on original drawings.
