CUSTOMIZING HOLE WIZARD
I created a new Hole Wizard standards for tapped holes and such. I wanted these new standards to come up as default, so I disabled ANSI metric holes, leaving only the custom standards I created.
Now when i go to use the hole wizard I get the error: The derived Standard 'Ansi Metric' does not exist in the database. Using the parent of this standard instead.
After this error my custom standards are select and everything works. However I would not like to see this error anymore. Can anyone help?
Matthew
Matthew
RE: CUSTOMIZING HOLE WIZARD
Dan
www.eltronresearch.com
Matthew
Do you always get this message or only when you try to edit a hole wizard hole done with the old standard?
Regg
