Type BT (Type 25) Plastic Thread Cutting Screws
Where can I find recommended tightening torque values for type BT plastic cutting screws?
RE: Type BT (Type 25) Plastic Thread Cutting Screws
I would guess that once you know what material is, you could ask the screw supplier. Usually it's a case of try some as there are many variables.
(You don't mean a PT screw do you?)
Cheers
Harry
