Wanted: Vendor for small composite, titanium, or Alum Press. vessel
Hi All,
Does anyone know of a good vendor for small composite, titanium, or Aluminum Pressure vessel that would be off the shelf and not custom? Specs for pressure vessel:
-approx. 7000 Cubic Inch Capacity (can be smaller, I can string together a couple vessesl to reach my size goal)
- either spherical or squat circle in shape
-Ports each end
-Tank is meant to be a test ballast tank in a underwater application, so tank must be able to resist seawater on the outside and inside.
-Tank must be able to resist 750 psi pressure on either side of the tank wall.
-Would be nice if there is something to attach to on the tank to tie it down
-Tank does NOT need to meet ASME standards. Tank will be used as part of an R&D effort.
Is their such an animal out their? I have thought of using COTS scuba tanks but am somewhat concerned with internal tank corrosion (even though the tank internals would only be exposed to seawater for a very small amount of time).
Thanks for your time,
Gordon
-Ports each end
Gordon
RE: Wanted: Vendor for small composite, titanium, or Alum Press. vessel
Can you use Cylinders?
Gordon
http://www.catalinacylinders.com/index.html
