welding SS310
welding SS310
welding SS310
I need to calm down a staborn customer which insist in welding repairs for his SS310 carburize fixtures. I now from experience that once carburized, the welds wont last more than few runds.I need few direction to start make a presentation based on theory. What book or resources should I use. Is the carbon equivalent problen,Ni equivalent problem,filler,etc?
Thank you,
A
RE: welding SS310
Turda;
The web site below contains a succinct explanation of the damage associated with a local carburization zone in 310 ss.
I would not recommend welding on 310ss furnace fixtures that have been in service unless you are prepared to remove the carbon contamination layer where the welding will be performed, and weld using 310 filler metal. You will need to determine the depth of the carburized layer to get back to lower carbon base material, prior to welding.
http://www.sandmeyersteel.com/310-310S.html
RE: welding SS310
Thank you very much.A
RE: welding SS310
Carburized fixtures are extremely brittle and won't last long after weld repairs. You can also observe that in the weld regions there are cracks.
Ofcourse it is very difficult to make a decision to replace with a new one. Hence life extension methods are adopted,unfortunately in this case without much benefit.
" All that is necessary for triumph of evil is that good men do nothing".
Edmund Burke
