Full penetration with backplate-any removable backplate
Pals
Is there any kind of material used as backplate and that can be removed after welding
Is anything wrong with removing them?
Backplates are handy but we can not figure how to remove them
respects
IJR
respects
IJR
RE: Full penetration with backplate-any removable backplate
http://www.gullco.com/more_katbak.html
In most cases there's nothing wrong with removing them.
ESAB and Cerbaco also supply ceramic backing systems.
Do "heavy" copper and "water-cooled" copper eliminate the "melting" of copper problem entirely?
respects
IJR
We have recently qualified manual and automatic FCAW procedures using the Cerbaco ceramic backing with excellent results. Ceramic backing design is highly important to provide the most desireable and repeatable weld profile.
