Railway bridge design books etc?
im currently been assigned to design a 60-m railway bridge for light rail train.
im new on this and i need info on the design considerations, design criteria, design loads/load combos, special detailings and anything about railway bridges anyone?
RE: Railway bridge design books etc?
Good Luck.
AREMA should not be used as it is too heavy.
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
AREMA does publish guidance for railroad structures (including bridges) and light rail applications.
That having been said, other transportation codes/standards should also be consulted, such as AASHTO's LRFD Bridge specifications, especially if there is a federal funding component.
See:
http://
http://www.cement.org/transit/
-Jeff
