a/c lineset vibration & noise
On a fairly new a/c installation (1 year) there is a vibration and sound that is transfering from the a/c compressor to about the first 12 feet of copper line set.
Is there a way to limit this sound without re-working the whole line set and having to recharge the system?  The suction line is insulated and the contractor mortered the opening where lineset passes through the masonry foundation wall.
Thank you.
RE: a/c lineset vibration & noise
You may want to throw this one "over the wall" to the Acoustics and Vibrations forum (forum384: Mechanical Acoustics/Vibration engineering).  There are plenty of ways to isolate and remove the vibration / noise from the simple to the complex, but forum384: Mechanical Acoustics/Vibration engineering probably has a pretty good opinion about how to handle it.
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Magnitude The Finite Element Analysis Magazine for the Engineering Community
