Routing problem
Routing problem
I can't get a 2d drawing of my wire diagram. The program seems to be missing the wiring button. I have routing turned on but not everything is showing up. I have been talking with SolidWorks and they can't seem to figure it out. SolidWorks 2007 SP4
RE: Routing problem
You can bring your assembly routing into a drawing and it acts just like a model in SW does.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
RE: Routing problem
Are you trying to create a 2D harness manufacturing drawing?
Is so try:
Click Routing > Electrical > Harness > Wiring Summary
select the route sub assemblies
and click Open Drawing
RE: Routing problem
There is no harness command.
RE: Routing problem
Solution Id: S-015672
Question: In SolidWorks 2007 SP4.0, the harness menu is missing from the Routing > Electrical menu. What can be done to resolve this problem?
Answer: There was a problem with the harness menu not being present on some installations of SolidWorks 2007 SP4.0. This occurred with the 32-bit version of SolidWorks. It did not occur with SolidWorks X64. This problem can be resolved by installing the Hot Fix attached to this Solution: HotFix_384858.exe.
You will have to search this Solution up yourself to find get teh hotfix.exe.
Please use the KB first as its a very useful tool for SW.
