added monitor
added monitor
added monitor
I now have a 19" flat panel and would like to add another 19" monitor. If I go with a standard fpm it doesent offer dvi. But if i go with a widescreen it will. I have a FX1500 and would like to use the dvi. Will there be a problem with the different resolutions. The wide sceen at 1440 and the other at 1280.
RE: added monitor
You may have to adjust each monitor's settings until it looks right to you.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
RE: added monitor
You can use monitors with 2 different resolutions, but it works easier if the vertical resolution is about the same.
