4 CHOICES INTO ONE CELL
You can see that I am trying to fill a cell on another worksheet, but with this code, it always ends up blank because A145 is blank.  How do I keep this from happening?
Range("A139").Copy Destination:=Sheets(1).Cells(279, 1)
Range("A141").Copy Destination:=Sheets(1).Cells(279, 1)
Range("A143").Copy Destination:=Sheets(1).Cells(279, 1)
Range("A145").Copy Destination:=Sheets(1).Cells(279, 1)
RE: 4 CHOICES INTO ONE CELL
You are copying a null value into Cells(279, 1).  Why would you expect anything other than null?
As your title says, you're copying 4 results to the same cell, so the last copy is the one you see.  Why would you expect otherwise?
TTFN
your exactly right and I know that.  But if I say...I put a number in Cell A143 i want that number to go Sheet one Row 279 Column A.   But as you said, it will look at the last macro.  So I am trying to make a macro that will look at all four and input the highest number
I'm not trying to be mean, but you're really not providing us much information in your original question with which to help you.  Nowhere in your original post did you say that you wanted to pick the highest number out of those few cells.
For starters, if this is all you want to accomplish then there's no need for a macro.  Just use the MAX() function of Excel.  The formula in Sheet 1 Row 279 Column A would be
MAX('WhateverYourSourceSheetNameIs'!A139:A145)
If you really want to do this in code, then use the line
Sheets(1).Cells(279, 1).Value = Application.WorksheetFunction.Max(Range("A139:A145"))
Having Excel cut and paste through code is rarely the most efficient way to go.
I agree handleman... an important notation in which I did not provide.  Sorry about that and thanks for all your help!
