Mediun pressure air from a high pressure source.
By the costumer requirement I have to supply 2 m3 /min at 0.5 bar,or 70CFM at 7 PSIG .
Of course the best option to it is a ROOTS type blower.
But I want the source to be a 7 bar or 100 PSIG commpresor , just because I need to filter and dry the air to be esteril, and I can not get filters mean to be used at 0.500 bar .
So I will have the air dry and filter at the 7 bar , and then I will drop the pressure by a diaphragm regulator to 0.5 bar.
Also as the pipe will be small it will lower the commissioning cost.
The task to do is to supply air to a RUSHTON mixer in a aerobic process , so the air shall be input under about 2500 mm water column , the rest of the pressure will be lost in valves and piping etc.
RE: Mediun pressure air from a high pressure source.
