Decal Position Changing in Model to Drawing.
Good morning, I have a model with a decal on it and the text on the decal is parallel with the bacl of teh part's should in the model. When I import it into a drawing and change the display style to shaded with edges, to make the decal visible, the decal has shifted 180 degrees and now the text is parallel to the front shouolder instead of the rear shoulder. Can anyone tell me what is causing this is it will stop. There are 3 dozen or so of these and it is happening to most , if not all of them. Thank you in advance for any assistance on this problem.
RE: Decal Position Changing in Model to Drawing.
Does this happen on other PCs?
Does it happen consistently with the same decals on different parts or different decals on the same parts?
How are you creating the decals?
Dan
www.eltronresearch.com
