issue with ENOVIA VPM
hi GUYS,
I am working with Enovia vpm. Whatever the assembly and we make will be in Enovia.Now i need to save all the parts and assembly as a backup which are in vpm.Therefore I tried in dmu ,save as frozen-save all products and data.It works but system is not able to handle as the number of parts present in the assembly is approximately 1400 including all instances.Can any of guys you please suggest of any other method possible.
RE: issue with ENOVIA VPM
Your network administrator don't make a back-up for your database? Keeping a personal back-up its not so wise (if this is the case).
Fernando
No, we need to do it by ourselves as we are the people who will be working with enovia vpm
Fernando
We cannot try to copy all individual parts each at once as it is time consuming if we try to copy all the parts all at once the systes strucks.
Fernando
Fernando
Fernando
