Mercury resistant Aluminum
Has anyone heard of an Aluminum that is resistant to corrosion from Mercury?
Thanks for any input!
RE: Mercury resistant Aluminum
If someone has developed such an alloy, then it would be by using some form of barrier coating.
S.
http://www.corrosionist.com
If there is some need to use aluminum in an Hg-containing environment, I suggest that the best barrier coating would be Micro arc oxide (MAO) aka Plasma Electrolytic Oxidation (PEO) + PTFE copolymer + PTFE.
I.e., Keronite® + Teflon.®
http://www.intetech.com/content/view/83/0#mercury/
hope this help you
S.
As an engineer in Petrochem, the OP question had my alarm bells ringing too!
We recently spent some bucks installing mercury removal beds due to a feed slate change - we have several Al plate finned hX's that otherwise would have been compromised.
"Life! No one get's out of it alive."
"The trick is to grow up without growing old..."
