PRV Set Pressure above Critical Pressure
I have an exchanger and piping with HyydroCarbon which is protected by a PRV.
The exchanger is a steam heater and the steam is hot enough to vaporise the HC.
The Critical conditions of the HC stream are significantly below the set pressure of the PRV;
What happens to the vaporisation rate or vapor density at relief conditions?
RE: PRV Set Pressure above Critical Pressure
R. Ouderkirk, "Rigorously Size Relief Valves for Supercritical Fluids", CEP, August, 2002
Corrections: CEP October 2002
Letters to the Editor: CEP November 2002
Letters to the Editor: CEP January 2003
