Position Sensors
Position Sensors
Position Sensors
we've designed a cylinder that has a position sensor on the extend side.  the sensor uses a magnetic field to engage the switch.  we tested the cylinder and got some screwy results.  after some extensive analysis, we finally realized, our rod is stainless steel. Oops.  my question is, does anyone know if there are position sensors that are combatible with stainless steel?  Thanks ahead of time.
RE: Position Sensors
Sure, any nonmagnetic proximity sensor should work fine.  Take your pick.  Optical, visible or infrared, ultrasonic, microwave.
http://virtualpipeline.spaces.msn.com
Also mechanical switches.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
For whole aluminium cylinders with al.piston, magnetized inserted strip as part of piston construction is used.
