24vdc to 12vdc voltage regulator
I have a 120vac to 24vdc transformer that will output 4.5 amps. I'm looking for an inexpensive way to step this down to 12vdc at 4.5 amps max. The current draw is not allways at 4.5, sometimes it is lower. Any suggestions on the best way to do this?
Thanks in advance.
RE: 24vdc to 12vdc voltage regulator
Sometimes I wake up Grumpy.
Other times I just let her sleep!
You can pick one up for around 40 bucks easily...
or just get a 24vdc to 12vdc convertor.. again cheap..
Can you point me to a web site where I can pick up a $40 120vac-12vdc with 5 amp capacity? I have not seen one that cheap, but I'm probably not looking in the right place...
http:/
Keith Cress
