NDT of Existing Framing
I have to come with a plan to investigate the capacity of an existing welded steel pipe framing. The structural framing is exposed in a marine environment, and have spots that are starting to rust and pit.
My main concern are the welded connections (pipe-to-pipe, and pipe-to-gusset plates). We are planning to NDT all the welds that show signs of corrosion, and my question is: What type of NDT should I use, and why?
Magnetic particle and colorant dying would test only the top 1/4" or so of the weld.
Ultrasonic and X-ray testing could be difficult in some places because of the framing geometry.
TIA
AEF
TIA
AEF
RE: NDT of Existing Framing
Always use proper personal protective gear and safe, approved working techniques.
Good luck and work safely.
Rod
UT can detect and measure corrosion. RT can show the extent of pitting. Sometimes a combination of methods is useful.
Recommend You submit this thread in the forum for NDT:
QC, Inspection & Testing engineering Forum Forum286
Regards, Wil Taylor
Thanks for your responses. They were very helpful.
I am considering ultrasonic testing for accessible places, and dye-pen testing in places where ultrasonic could not be used.
Most of the T and K connections in the piping frame are Ok. The pipe-to-gusset plate connections are the ones that show more signs of corrosion.
Thanks again
AEF
