contoured structure
contoured structure
contoured structure
I have modeled structure in an assembly and it all needs to be warped to a specific contoured surface. Is there a way to force structure to follow a contoured surface without recreating the structure to the contour? Thanks
RE: contoured structure
Could you post an image of the contoured surface with a Shaded Curvature Analysis or tell us if it's cylindrical.
I believe you can do this with a Spinal Bend but if the surface is more complex you made need to use the Warp Tool in Wildfire.
Michael
