Air intake duct design
I work at a hospital and we're having an air intake duct of 24"x16" with an approx. length of 125' and 3 elbows which will need to handle 48,500 CFM ( 3 different air handlers) and I think it's undersized. Any help?
RE: Air intake duct design
Just a comment on BronYrAur's post, 500 fpm is a good rule of thumb for louvre sizing, but I generally recommend that you review the louvre manufacturer's sizing charts. They will list a point of 'rain penetration' on their charts which can vary significantly depending on louvre design.
It may be that your total AHU has the 48500 cfm, the OA flow at about 10 -15% of that amount (old rules of thumb) would make the OA cfm at about 4000-6000 cfm. Even with this senario, the 24X16" is too small. I believe 1000 fpm is max velocity I would bring air in. This will be about 2400 cfm outside air.
Going back to your question: yes the duct seems to be bery undersized no matter which way we look at it.
