CAtia V5 surface
CAtia V5 surface
Could somebody explain me what is the difference between a Catia V5 file which contains surfaces using the GSD workbench only and another file which uses Body-in-White or/and class "A" surfacing? When is necessary to use Automotive class "A" and BIW workbenches for creating surfaces instead, of GSD? Or when should I create a Catia V5 file, using both the GSD workbench and Automotive class “A” and/or BIW workbenches?
Thanks!
Thanks!
