Chemical Treatment in Hot Water Pipe
Could anyone please advise whether or not the chemcial treatment for the hot water piping is required? The hot water is produced from the co-gen facility, and the hot water supply and return piping run about 5,000 ft long from the co-gen facility to serve an industrial plant. The suply water temperature is around 200 Deg. F, and return temperature is around 180 Deg. F. I understand the chemcial treatment is required for the makeup water for boilers, heat exchangers, etc., and the co-gen facility in this case, but am not sure if any addtional treatment system is required for the water at the industrial plant since the piping runs are so long. Could anyone please advise? Thank you very much!
