DIN 17230 equivalent?
We are quoting a project that requires pins manufactured from DIN 17230 rolling bearing steel. I see that rolling bearing steel is usually 100Cr6, but if the customer specifies DIN 17230 only, would it be considered the exact equivalent? I am primarily interested in chemical composition and hardness.
Thanks for any help you can provide.
Kim
Kim
RE: DIN 17230 equivalent?
Kim
