water cooling
water cooling
water cooling
Please, can anybody direct me to some materials / experiences for the case when during the well testing quantity of some 4 000 m3 of water/day has to be cooled from cca 85 C to 20 C before it is discarded to surface natural waters
Thank you
RE: water cooling
hmmm- intersting problem!  the obvious place to go for expereicne with this owuld be the testing companies- Schlumberger, Geoservices, etc.
RE: water cooling
hmmm- intersting problem!  the obvious place to go for expereicne with this would be the testing companies- Schlumberger, Geoservices, etc.
RE: water cooling
If the water is clean (ready to be discarded) and the "natural waters" is colder than 20 deg C - then why not just "premix" it with these "natural waters". Lay out a hose and pump up the water and mix it so that the resulting temperature is 20 deg c?
Best regards
Morten
RE: water cooling
Air coolers would be used to lower the temperature, then something else depending on ambient.
A cooling tower or evaporation pond would work.
I believe your problem will be mineral deposites.  As the water cools, you will precipitate minerals, if the water as them, an most produced waters do.
RE: water cooling
That is a bunch of water and an awful lot of heat rejection.
The heat works out to 2.6E8 kJ (2464 MMBTU/day or the equivalent heat of 2.5 MMCF/d of methane).  I don't know any "quick and dirty" way to get rid of that much heat.  If you have a bunch of surface water (i.e. offshore) then you could design a specific water-water heat exchanger to pump a few million m^3/day through one side to result in your produced water being at the right temp without the heat exchanger exhaust being too hot.
I recently designed an evaporation pond for 1/5 that much water and the pond surface was 75m X 75m.  I don't think that you're going to be successful rejecting the heat to atmosphere.
David
RE: water cooling
I just realized that I used 1 cal/gm-C when I meant to use 4.18 J/gm-C.  Call it 10,7E8 J, 10,102 MMBTU, and 10 MMCF/d of Methane equivalent.
David
RE: water cooling
If this is an ongoing produced-water disposal problem, suggest you look at a binary-cycle power generation plant such as ORMAT (Israeli I think).  These systems use Propane or Ammonia as the power fluid and don't recall the OA efficiency but would think that you could generate quite a few MWe.  $100/BBL for your oil and $10/BBL for your water?
Aside from capital cost, a problem you may run into is Calcium Carnonate/Barium Sulphate etc precipitating out in the heat exchangers as the temperature drops.
