How to "unhide" columns
I naively chose in hide columns in the MS Project Gantt chart and I am now unable to "unhide" them - should be straightforward, but I am obviously missing something.
Any ideas?
Marc
RE: How to "unhide" columns
You have to right-click on the columns (where is the field name) and choose "Insert column", then select the column you want to display.
Hi Marc,
Unfortunately, 'hiding' doesn't mean what it suggests - it actually means delete column. When you do this, you don't lose data though, so you can reinset the column by clicking on the column name to the right of where you wish to insert and on the Insert menu, select column. Follow this by defining the field name and title etc.
Good Luck,
Rentaplan
