Double sided butt weld joint
On your opinion, according to ASME B 31.3,is it possible to weld some welded neck flanges by using a double sided butt weld joint ?Thanks for your help.
RE: Double sided butt weld joint
Potentially it would be good for avoidance of fatigue when compared with the usual unbacked butt weld.
