Caustic tank overflow line
Looking for help in regards to a design question.  I have a caustic tank with a vertical overflow internal pipe that connects to a siphon breaker through the roof, then u-bends down to a nozzle attached approx. 2' above floor.  There is an engineered sump for retention, and the nozzle  through the 1st course is open to atmosphere (flange connection not blinded).  Is this a standard or acceptable situation?  Should'nt the lower overflow nozzle be connected to secondary containment or blinded?  Any help appreciated.
