Corrosion book recommendations
As an entry-level mechanical engineer I'm studying my way up to be familiar with all aspects in the field including corrosion engineering. Can someone recommend me a basic corrosion related handbook? As a design/mechanical engineer I have found myself lost in choosing the most efficiency material. My company deals with both metals and plastics.
Thank you,
Sung Hong
Thank you,
Sung Hong
RE: Corrosion book recommendations
ht
These are very comprehensive (and expensive).
Perhaps a lower-price, single volume would meet your needs. Uhlig's is a popular book:
http://ww
Corrosion Engineering by Fontana is a little older, but a very good book:
http:/
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
There are some great books available from MTI. www.mti-global.org These are good if you work in specific environments (acids and such).
The ASM Corrosion Handbook is now in three volumes.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
Materials Selection for Hydrocarbon and Chemical Plants
htt
hope this help
S.
http://www.corrosionist.com
htt
For some freebies:
http://www.usace.army.mil/publications/
EM-1110-1-4008 Liquid Process Piping.pdf
EM-1110-2-2704 Cathodic Protection Systems for Civil Works Structures
EM 1110-2-3400 Painting - New Construction and Maintenance (30 Apr 95)
TB 43-0213 CORROSION PREVENTION and Control including Rustproofing for Vehicles (1990)
TM-1-1500-343-23 AVIONICS CLEANING AND CORROSION PREVENTION CONTROL
TM-5-622 Chapter 7 -- Steel Structures & Corrosion Protection
[lots more if one cares to browse or search]
http://assist.daps.dla.mil/quicksearch/
MIL-DTL-14072E Finishes for Ground Based Electronic Equipment
MIL-HDBK-1110 HANDBOOK FOR PAINTS AND PROTECTIVE COATINGS FOR FACILITIES [aka UFC 3-190-06 Protective Coatings and Paints.doc]
MIL-HDBK-132A PROTECTIVE FINISHES FOR METAL AND WOOD SURFACES
MIL-STD-7179 FINISHES, COATINGS, AND SEALANTS, FOR THE PROTECTION OF AEROSPACE WEAPONS SYSTEMS
MIL-STD-889B [also Notices 1 & 3] DISSIMILAR METALS
look also at this publications:
htt
https:/
htt
ht
http://ammtiac.alionscience.com/pdf/AMPQ9_3.pdf
hope this help you
S.
