HVAC CAD DRAFTING SOFTWARE
Greetings HVAC gurus,
what is the most popular or best
HVAC cad drafting software currently around
which can be used with Autocad
for drafting ductwork or ventilation.
PUMPMANPLEE
RE: HVAC CAD DRAFTING SOFTWARE
Do a search for
"hvac software"
It depends on what you want the software to do and how sophisticated you need it.  Some software can do 3-D ductwork modeling, some can perform basic load calculations and size ductwork according you the desired CFM.  Autodesk is a good piece of drafting software that I use with Autocad.
This is the product we use http://www.intelicad.com/index.html Most of our work is sheetmetal. We like the product and support is ok.
Autodesk ABS, East Coast Software or Quickpen are all 3D and good
