plot problems-cannot plot dimensions ACAD 2006
My plots have one problem. The dimension text is not printing.
The dim lines, arrows, etc. do print. Any regular text placed on this layer also will print.
It only occurs on a new drawing that I just created. Not previous ones. I cannot find any settings that are different, but there must be one somewhere.
It seems to me that I had this problem once before, but I can't remember the solution. I use ACAD 2006
Paul Ostand
www.ostand.com
RE: plot problems-cannot plot dimensions ACAD 2006
Paul Ostand
www.ostand.com
Correct??
Even so color, linetype, and lineweight are set "ByBlock"
Text style is "Standard", color "ByBlock"
Layer color is "white"; control "By Layer"
Paul Ostand
www.ostand.com
This is frustating!
Paul Ostand
www.ostand.com
I set a new dimension style. Then erased the existing dimensions (there were not that many) and re-dimensioned using the new style and it is now ok.
I do not see what was really different between the two style settings. That is still troublesome, in that I do not know what I may have done incorrectly.
Anyway, I am back in business, and thanks to you who tried to assist.
Paul Ostand
www.ostand.com
