Tapered Beam Deflection Coefficients
I have been working on a project where we need to check the deflection of a tapered beam and I have been looking up in Roark's "Formulas for Stress and Strain" Table 13a at the deflection coefficients for an end loaded cantilever beam look wrong or the table header has a typo as he has Inertia at Fixed End divided by Inertia at Free End of say 2 gives a deflection multiplier of 0.579 which would then reduce the deflection if you using the inertia at the fixed end to calculate the deflection, or am I wrong in this assumption and that to calculate the deflection of tapered beam you use the inertia at the free end in which case Roark's table would be correct.
RE: Tapered Beam Deflection Coefficients
If ever there was a time for finite element, then this would be it.  Run a SolidWorks model using COSMOS.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Tapered in depth, or width? I can assure you that a linear taper in wdth is a solvable equation, since I solved it last week, and I'd be a bit surprised if the depth case was any harder.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Take a look at your strength of materials book and look for energy / virtual work methods. An integral or two later you're done.
However, since I'm far more proficient at SolidWorks / Cosmos than calculus, I'd take Cockroach's approach myself...
jt
