[b]Finding amplitude from PSD data?[/b]
A question to those of you who probably have a far greater knowledge about this than me!
I have a PSD plot (g2/Hz) against frequency, there are very distinct peaks at certain frequencies. Very simply I want to find out what the displacement of the object would be at these frequencies.
I am sure this must be easy but.....
Thanks alot in advance
Parsnip
Parsnip
RE: [b]Finding amplitude from PSD data?[/b]
What do you mean, the travel of the vibration head or the deflection on the part due to Fn?
Tobalcane
"If you avoid failure, you also avoid success."
Basically the accelerometer was mounted on the vertical axis of the excited part, the PSD was 0.004 g2/Hz at 504Hz, what I want to try and find out is how much has that part moved. Does that make sense?
Cheers
Parsnip
BUT, unless the random background is VERY low, the total random displacements might exceed the contribution from any single line.
TTFN
TTFN
a~0.6 m/s^2 rms
x~5*10^-6 m rms
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
How do we convert that PSD into acceleration in g's?
I would assume two steps:
1 - Integrate over a certain frequency band.
2 - Take the square root.
What frequency band should be used for step 1?
So for instance, in this case, suppose the sample rate was 8192 pts/sec and the frame length was 1024 points, then the frequency resolution would be 8192/1024 = 8 hertz. Then, using the OP's data:
Average amplitude = sqrt[.004 g2/hz* 8 hz] = .179 g
Peak Displacement = (.179 * 386 )/((2*pi*504)**2) = .00000689 inches
that should be m/Hz
Cheers
Greg Locock
Cheers
Parsnip
