Timber Frame Models
Timber Frame Models
Hi all,
When you model TF frames do you put a joint (i.e pinned) at all connections. This seems weird b/c if you mortise into a meber it still has substantial capacity and won't really act like a hinge.
RE: Timber Frame Models
A glued mortised joint will have some moment capacity but your design should show that it is adequate if you are going to use it.
