Two-horspower collector's item (an automotive forerunner)
Chariot with scenes from the life of the Greek hero Achilles
Etruscan, Archaic, 2nd quarter of the 6th century B.C.
Found near Monteleone di Spoleto in 1902
Bronze inlaid with ivory; total height: 51 5/8 in. (131.1 cm); length of pole: 82 1/4 in. (208.9 cm)
The Metropolitan Museum of Art, New York, Rogers Fund, 1903 (03.23.1)
http:
RE: Two-horspower collector's item (an automotive forerunner)
It's not a trick question.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
The engine mount look like they'll take quite a variety of power units.
Bill
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I see. Perhaps they could be boosted somehow?
Avenues for investigation:
- higher calorific value fuels
- improving the coeff of friction between the power units and the road
- afterburning the increased waste gasses as a result of the higher cal value fuels
- a sharp stick
Bill
http://www.snopes.com/history/american/gauge.htm
The Japanese word for rail car is transliterated as "sharyo" shar-y-o, which is pronounced remarkably similarly to chariot.
Dan - Owner
http://www.Hi-TecDesigns.com
Nick
I love materials science!
No air conditioning, you're positioned right behind the power plant's exhaust, "fueling" took an hour in a grass field, no theft deterrent, and you couldn't leave it in the driveway unattended for months on end.
Dan - Owner
In highly aggressive driving conditions, it would be advantageous to attach the ancient equivalent of the spinner hubcap to the axle, if they were attached to the wheel when utilized in heavy traffic may cause undesireable effects on the users vehicle, as opposed to the defeding vehicle.
http://en.wikipedia.org/wiki/Spinner_(wheel)
http://en.wikipedia.org/wiki/Chariot_tactics
A quick side ways move pushed the axle of one chariot into the wheel spokes of the other thus damaging the wheel and putting the opposition out of the running.
This assumes the opposition had not also thought of the same trick.
Bodacia (spelling?) was reputed to have had long blades fitted to the revolving hubs of her chariot to scythe through the rampaging hordes of the attackers.
Pete.
Mike Halloran
Pembroke Pines, FL, USA
There are some zoomable pix at the Met muzeum.
Re the oxen upgrade; That may exchange draw bar pull for velocity with the same or reduced HP.
Anyone have a current Hp to Op conversion chart?
Yours
Bill
http://www.youtube.com/watch?v=i1650bztvpY
http://www.youtube.com/watch?v=-yv-6XDSrvM
100% guaranteed performance enhancer.
