How to Calibrate a WaterCAD Model
Am new to WATERCAD and have laid a hydraulic model for a community and attained hydrant flow test data.  How do I calibrate the model to verify it matches field data?  Do I just run fire flow analysis and adjust the global demand / roughness as the manual suggests until model matches field data?  Or do I input my field flow data individually for each hydrant(node) and keep adjusting that pipes roughness until it matches field data.  Or is there another way?
  I am assuming I run the model checking fire flow analysis for either option.  Then once the model is calibrated start inputting in all the average / max demands from there?
thanks
