Storage tank with design temperature of 300F
wich API standard shall apply to a storage tank working under 15 PSIG @ 300F?
Note : API 650 has maximum temperature of 260F (Appendix M) & API 620 has maximum at 250F
Thank in advance,
hjulien
RE: Storage tank with design temperature of 300F
Neither strictly apply.  API-650 only goes up to 2.5 PSIG pressure but 500 degrees F in App. M.  API-620 goes up to 15 PSIG, but only 250 degrees F.  You could use API-620 and modify similar to API-650 App. M, or switch to ASME Section VIII or some other standard.  It would partly depend on the size and application as to which route I would persue.
